Tool file for Fusion 360 CNC is empty
I have an A350 and Fusion 360. I want to use the CNC fuctionality like the video tutorial "Fusion360 CAD und CAM shows.
I downloaded the Tool Libraries here : https://snapmaker.com/product/snapmaker-2/downloads
There are 2 files:
Snapmaker 2.0 CNC Tool Library.tools and
Snapmaker Original CNC Tool Library.tools
If I import the CNC tool for Snapmaker 2.0 there are no new CNC bits inside Fusion360.
If I import the Orignal tool file I find 2 CNC bits. (like they are included in SM2.0.)
Not 3 like they are included in SM Original.
I’m running the newest version of Fusion - but I think that’s not a Fusion360 problem.
It’s a Snapmaker problem.
For what is the “Snapmaker 2.0 CNC Tool Library.tools” file ?
.tool is a zip file… unzip it first then import the files inside of it.
ATOM thank you for the answer.
You are right - it is a zip file.
I unzipped it and found a Java Script file with the decriptions of the tools.
So - something is in the *.tool file.
But the import of that *.json file brings the same result as importig the *.tool file - NOTHING !
It look like the Jave script is not correct - or the import format of Fusion 360 has changed.
I’ll compare bothe *.tool files - maybe I can find a reason.
I found the reason !!!
Inside the Javascript file there are 8 lines with Chinese letter.
Topic: Preset - variable: name - don’t know what the meening is.
I changed it into englisch words (just china1 - china8) - and now it works !
Seems, that Fusion360 German Version don’t like Chinese letters.
There are 2 possibilities:
  1. It’s only a problem of the German version – or
  2. Nobody tried to use Fusion 360 for CNC (even the Snapmaker people)
I was able to import them without any problems. I did use the version from the github page, but I assume they are the same: https://github.com/Snapmaker/snapmaker_cnc_post_process
Using Fusion360 in English.
brvdboss:
I looked at the GitHub page, but I cannot find the tool files. (*.tool)
I can only see the “posrprocess” file.
Can you help me please to find these *.tool files ?
regards
K.D.
It’s in this directory:
OK - Thank you I found it.
But there are to Chinese words included too - strage.
It looks like it is a problem of the German version.
But I replaced these words and now it works.
Yeah, even in the English version of Fusion 360 some of the tools have Chinese text appear - no idea what they actually say but unlike the German version it doesn’t stop the files from importing. I kept meaning to log a ticket in Github but never got around to it.
