I’m having the following issue:
My (original SM) nozzle temperature rises, but does not stop at the set temperature. Smells to me like a controller issue.
Any bright ideas?
Thanks
Arnaud
Any bright ideas?
Thanks
Arnaud
Whats your M503 output? Did you edit your pid setting?
Did you check if the same thing happens with a freshly assembled hotend?
Is the thermistor well assembled?`
Hope this helps.
Thanks Chris,
As I have the same issues when I go to change filament mode I assume it has nothing to do with my code.
In fact the problem started after a print can’t lose and clogged the full nozzle. I had to replace the hit end, heater and thermistor.
I guess heater and thermistor are ok, as I see the temperature increase.
Something must have gotten messed up…
What is the M503 output you u mentioned?
Thanks for thinking along…
You have to connect your machine via serial connection (USB) and type into the terminal of Luban M503.
USB mini B (machine side) to USB A (PC side)
If you are really new maybe this helps;
If the nozzle cannot stop heating even you click the ‘Change filament’ on the touchscreen, the issue may lie in the controller.
Hope this article helps.
