Hey community! is there a way to cut a SVG Or DXF file when you have multiple images in that file? For example, I have this mandella svg file and it has all the layers on one file. It is too small if I cut it out that way. 4 to 5 different images. I want to delete all but one of the layers, cut it and then move on to the next layer. I know lightburn does this but I am having trouble running my Snapmaker from it. It Homes , goes to the origin , and frames the image but does not move when you hit run, this happened after my firmware update. I went back to an older version and still no go.
You could use Inkscape to seperate the layers into single images and process one after the other.
You could try drawing a rectangle over it and use the Mask function.
