Hi All,
So i have a drawing in cad for some tags I am making. When i convert to DFX and open all is good. But when i put it into Luban the writing doesnt come up. Just all the lines.
Any ideas?
Hi All,
Any ideas?
Hey, do you mind uploading the DFX file here? I will transfer it to our software development team to check the problem. And for a solution, i will suggest you try to convert to svg file. If you have concern about the copyright, you can send it to our support team privately via mail.
Hi there, using SVG files is not an option. dimensions are not equal to the ones in the DXF files. I’m struggling with this problem since a couple of months now. Any curved line in a DXF file is not a problem for Luban, but as soon as you use straight lines Luban it goes wrong. I really do nopt understand that Snapmaker is not able to fix this problem. Many users want to do cutting there own designs but this is not working in Luban. Really Snapmaker unworthy.
