Surface Studio — Automated 3D Mesh Painting & 3MF Color Export for U1 + Orca
I have read and understood all rules of the Innovation Fund Phase 2
on
I consent to my project information (username, project cover, summary, etc.) being publicly displayed for review and showcase
on
Username (for public display)
ohmicaudio
Project name
Surface Studio
Project URL
Project cover
Project Category
Software
Project Summary
What it is
Surface Studio maps ridges, recesses, and lighting into 3MF color assignments for the tested Snapmaker U1 + Orca beta workflow — without painting every face in your slicer.
Your slicer still handles cooling, supports, infill, and motion; Surface Studio prepares the multi-color assignments.
Input: STL or 3MF → Output: Separate Printable 3MF + Colored GLB
How it works
Base + feature layers — ridge, shadow, midtone, light — blend into printable colors.
Blends tested: blue base + red feature = purple; black + white = gray; red + yellow light = orange highlights; blue + red light = purple edges.
Feature-based, not hand-painted triangle by triangle: ridges, valleys, center areas, and recesses are treated differently by location on the model.
What I’ve built / validated
Private alpha, tested on Snapmaker U1 + Snapmaker Orca beta.
Dragon Bowl by TheHexArtist — physical print, tested U1 workflow
Gothic Castle model — physical print
Laptop runs (separate from print results):
Dragon — 835,450 positive triangles — 30.952s analysis, Ryzen 5 7520U laptop
Gothic Castle — 821,580 positive triangles — 30.174s analysis, same laptop
Single observations, not speed guarantees or system requirements.
Also printed: 3 pumpkins — orange base, black ridges/crevices, red edges/teeth/claws. Results vary by model and layers.
What it saves you
Hand-painting a detailed model takes hours. Surface Studio’s analysis pass on an 821,580-triangle model took about 30 seconds on a Ryzen 5 7520U laptop; after that, you choose layers and colors, not triangles.
Weathering works the same way: worn edges and grime are a layer, not an afternoon — light blend on ridges, dark blend in recesses. Two selections, two blends, done.
Alpha-plus — in testing, almost ready, not in the frozen release
32 layers, each with as many selections as you want — region masks, ridge selections, and more — via smart selection and painting tools.
Each layer has its own selection parameters, mapping sizes and parameters, and lighting — including multiple light sources, so two layers can take light from two directions in two colors — with its own blend. So Layer 2 can differ from Layer 1 in all of these — stacked up to 32 layers.
Status / access
Private alpha. Founder access: $9.99 one-time, personal use, tested workflow — but checkout is currently unavailable. Alpha access is free, by invitation; a request guarantees neither access, compatibility, nor a date. No payment is taken on a request.
What I’m asking for from the Innovation Fund
Support to finish validating the 32-layer alpha-plus on the U1 workflow, finish the release, and keep Surface Studio focused on easier multi-color U1 prints — without hand-painting every face.
Open Source Status
Closed Source
Please specify the open source license used by this project
N/A
Cash Fund or U1 Hardware Sponsorship
Cash Fund
Originality
Original New Idea
If based on an existing project — your independent contribution
N/A
Is it a paid project?
Yes
Live Workflow Video & Real Snapmaker U1 Print Progressions
1. End-to-End Snapmaker U1 Workflow Video
Watch Surface Studio go from raw 3D model → automatic geometry-driven shading → Snapmaker Orca slice → physical Snapmaker U1 print:
2. Real Snapmaker U1 Print Progressions (Mesh → Surface Studio → Snapmaker Orca → U1 Print)
  1. Dragon Showcase (Raw Geometry → Surface Studio → Orca → Physical U1 Print):
— Unpainted input mesh
— Geometry-driven shading generated automatically in Surface Studio
— Sliced in Snapmaker Orca for U1
— Finished physical multicolor print on our Snapmaker U1
2. Pumpkin Bowl & Clawed Pumpkin (Surface Studio → Orca → Physical U1 Prints):
3. Gothic Castle Print (High-Poly Geometry Shading on U1):
(Note: All photographs show real physical prints made on my own Snapmaker U1. Third-party STL/3MF art files are never redistributed.)
3. Coming Next (In Progress on Our U1 Right Now!)
  • 3.5-Day Full-Color CMYK / CMYW Dragon Bowl Print: Currently printing on our Snapmaker U1 right now! As soon as it comes off the bed, I’ll post high-res finished photos and a full showcase video right here in this thread well before the December 24 deadline.
  • Downloadable Original U1 .3mf Benchmark Model: I’ll also drop a 100% original multi-surface Ohmic test .3mf painted in Surface Studio so fellow U1 owners and the technical committee can slice and test the 4-slot toolpaths directly in Snapmaker Orca.
Feedback, U1 profile suggestions, and questions from fellow U1 owners and the Snapmaker engineering team are very welcome!
— Josh Lane (support@ohmicaudio.com, Ohmic Audio)
A note on this project’s history and originality
Surface Studio, in its infancy, was built prior to Round 2. I built it for Round 1 of this fund, but it was never completed enough that I considered it good enough to submit for Round 1, so it was never entered. The core of this project is my own original work — conceived and written by me, not copied or adapted from any other person’s project. Like most software, it is built using some standard open-source libraries as dependencies; they are tools the project runs on, not its core. What is entered here in Round 2 is that same original project, brought to completion.
