Supports problem in 4.11 and 4.12
The supports Luban is generating are not enough they skip parts that need support and others are just floating in mid sky and not attached to anything.
This with normal supports and 0 gap supports for pva.
Cura is calculating the right supports and filling them completely as they should. with the same model.
Hi Nancy,
This thread is according to the description of this forum the way to report bugs in versions of luban. I haven’t done it on GITHUB yet but will do also.
And i indeed also use cura but that has a little problem with the purge tower for the dual extruder. But i might have found a workaround for that. So i will try that this afternoon.
thanks for your reply.
Pretty sure Nancy is AI…
