Success: Runout for Octoprint, Host Action Commands, & Emergency Parser
I have modified the Snapmaker J1 firmware to enable several Marlin features for Octoprint users.
  • Filament Runout Detection/Handling.
  • Host Action Commands w/ Host Prompt Support.
  • Emergency Parser.
  • Support for Snapmaker’s M2000 tool-change gcode.
Runout handling is achievable using Host Action Prompts on the Octoprint web interface or on a Raspberry Pi screen running Octodash.
Configuration options:
FILAMENT_RUNOUT_SCRIPT in Configuration.h (default is M600).
NOZZLE_PARK_POINT_T0 and NOZZLE_PARK_POINT_T1 (position the nozzles park in upon runout detection or pause) in Configuration.h.
ADVANCED_PAUSE_FEATURE settings in Configuration_adv.h (lengths/speeds for retract, unload, load, and purge for M600 advanced pause, and other options as well).
You can look at the code and compile yourself, but I’ve also included the pre-compiled .bin file for you to install on your printer if you choose. Find it in the “release” folder. You need the file that doesn’t have APP in the name.
If you run into any issues or bugs, let me know and I’ll fix them asap. Enjoy!
Very nice!
You tested filament run out, or go to existing M600 command? (Only the latter didn’t work for me for jobs not started on the screen.)
I tested filament runout with M600 set as my runout script in configuration.h while printing via Octoprint. Works completely as expected. All configured advanced_pause_feature options worked flawlessly. I didn’t try a manual M600 from the terminal or inserted into the file before print. Just started a random print like normal with Octoprint and then cut the filament. Everything worked perfectly. I replaced the filament and repeated the process a couple more times too. Everything related to runout, including the use of other runout scripts or pause methods, should work just like standard Marlin but with HAC’s instead of an LCD.
Thanks so much for putting the work into this! I’ll have to flash it and give it a try soon!
Update: I got around to some testing.
I did a multi-extruder (non-duplication) print from HMI to make sure my code doesn’t interfere with normal prints using the Snapmaker HMI screen. Used default Prusaslicer profile to slice. Printing and tool-changes were normal. I triggered runout on each extruder and the native HMI runout handling was normal. No issues.
I did the same multi-extruder (non-duplication) print from Octoprint with the same slicer settings and ran into some issues which I have since addressed.
Issue 1. Standard Marlin allows you to configure a single NOZZLE_PARK_POINT which is where the active extruder parks on pause (ie in case of filament runout). However, the ideal park point for T0 is far left, outside of the print area and the ideal park point for T1 is far right, outside of the print area. Extruders can crash If they share a single park point that is too far left or right.
Fix 1. Configuration.h now has NOZZLE_PARK_POINT_T0 and NOZZLE_PARK_POINT_T1 so that you can configure separate park positions.
Issue 2. Snapmaker uses a custom gcode command for tool changes (M2000 S200). Originally, this gcode was incompatible with Octoprint. I have altered the code so that it works with Octoprint. This test resulted in successful tool change when switching from T0 to T1. T0 returned home and T1 continued the print in the correct location. However, when switching from T1 back to T0, T1 did not return all the way home. It stopped at x324 because it was restricted by software endstops.
Fix 2. Software endstops are now temporarily disabled during tool change. This is safe because no other motion gcode can be injected into the queue during this very brief period while M2000 S200 is executing. Software endstops are disabled just long enough for T1 to return home, and then reenabled.
These fixes are untested. I will be away from the printer for a week. Feel free to test and let me know the results.
*Current firmware version is 0.0.04.
If you’ve download a previous version prior to these fixes, please update to latest version.
Update:
I tested my previous fixes with the same dual extruder print and they were successful. The snapmaker M2000 S200 tool change gcode works with octoprint as expected now, and each extruder now parks in its own individual park position on pause/filament-runout.
I am going to call this mission accomplished. All that is left to test is filament runout during mirror and duplication modes with octoprint, but I will leave that to others. I am willing to fix any issues that you might run into if you report them to me, but I wont be doing any more testing myself. This has been a lot of work and testing for me already, and I feel like Snapmaker owes me a paycheck at this point lol.
Please enjoy. Let me know if you have any requests for firmware customization and I will be happy to oblige when i get some time.
I have flashed this to my J1s, and, it works great. Except that I get a LOT of spurious “Filament Runout T0” errors. They are easy enough to recover from, but it does require that I check up on the print status from time to time to make sure it isn’t paused.
Any thoughts on how to fix this?
Thanks again for the great upgrade!
Thanks, I’ll look into this and get back to you.
Since posing the question, I have some more data. Both T0 and T1 can produce spurious errors. Interestingly, the filament will sometimes fail to extrude, and no error is triggered. I thought that the J1 had a small wheel that turns, inside the orange housing, to report that the filament was feeding, and that an error would be triggered if the wheel stopped turning. That does not seem to be the case.
I think I found what could be causing that. Try the updated version (V0.0.06) on GitHub. I pre-compiled it as usual and it can be found in the “release” folder. Let me know how it goes.
I have the 0.0.06 version running. For those keeping score, it turns out that my problem with extrusion failure was due to the ribbon cable not being fully seated. So, that is fixed, and the extruder is now acting more sensibly. I just had a series of “filament runout” errors, which turned out to be a tangle in the filament spool.
I THINK I have fixed all the problems. I’m running an 8 hour print now, with runout detection enabled. We’ll see how things are in the morning.
Are you running full remote octoprint control for the print? Very curious how it turns out.
Yes. Slicing with Cura, with the Snapmaker plugin, save the gcode to local disk, upload gcode to Octoprint running on Pi attached to J1s, “load & print” the job from the Pi web interface.
I awoke this AM to find that the job was paused at about 20% completion due to spurious filament runout error on the support extruder (T1). Job resumed without problems.
My bowden tubes are pretty worn. I have replacements on order. My next step will be to replace the Bowden tubes and see if that helps.
I’m at work now, and do not have Internet access to the Octopi. I’ll have to wait until lunchtime to see if the job is still running.
Thanks for all the work on the Marlin firmware. What a shame you had to reverse-engineer code that was supposed to be open source…
Any chance to use a Miniton Beagle V2 to to control and monitor the print?
Kind regards
The Beagle doesn’t play well with dual extruders as far as I know.
Otherwise, with the printer obeying any old Octoprint server, a lot more should work with this firmware.*
* he said without testing or much thought
So, I was finally able to load this up and give it a go. Everything seemed to work as expected during my deliberate testing, until I tried to run a full (short, 45 minute) print using a proven dual-color model that I have printed successfully many times before. Then, I ended up getting quite a handful of spurious pauses. The pauses acted similar to a filament runout, but were not associated with a filament runout notification. Instead, I got the generic “printer paused” notification. Still, it acted like a filament runout in that the T0 print head (only T0) parked off the ooze pad, and upon resuming the print, it extruded a length of filament before moving to the print area. I never had this issue occur with T1, and it did not recur after reverting back to factory firmware.
Total occurrences were usually between 3-5 times during the print, and they always occurred between 70-99% print completion…though that might be a correlation/causation red herring.
Thanks for all the hard work you have put (and are putting) into this! Snapmaker owes you a paycheck.
Interesting. Do you mind sharing a picture or render of the model you were printing?
Just wonder if some particular feature may have caused trouble.
EG Page Holder.gcode (2.5 MB)
Here is a copy of the g-code and a picture. It is a fairly simple geometric shape, and I haven’t run into any issues printing it on the stock firmware. The pauses started prior to the dual-color layers and continued through to the end of the print…I’m stumped!
I’ll include the g code and a picture. Thanks for taking a look!
Yeah, that’s weird. Without slicing it, I don’t see anything obvious about the model. Simple looking geometry at first glance.
Did it fail at some particular level?
Also which extruders do you use? Maybe it’s just the old false clogs from the not-all-metal hotends?
To be sure, there’s no way for Octoprint to trigger the display interface on a clog. It would manifest as a pause you need to manage using the OP controls to resume. Good to see it still triggers and pauses though!
