I’m struggling dialing in settings to print a piece. It seems to warp. Not on the base plate but later on, near the top. I’ve attached the STL, it’s supposed to be a dome, but the edges warp up for some reason.
I would have a raft under all that support.
Support structure isn’t designed to do bed adhesion it’s there to support overhangs.
You might need to reduce the raft air gap so the support sticks well. This is usually a problem when you need to remove the raft but in your case it’s only support that will be touching the raft apart from a few very small points on the circular holes.
If I print so much support with a model, the first layer should be really slow to get best adhesion results.
An enclosure would help a lot to avoid warping.
