So I got the blob of death on print #1 on my SnapMaker U1. Toolhead 2 the nozzle is totally hosed filament all the way up inside the plastic sheeth. Took off the toolhead and disconnected it. Is there a way to use the printer without toolhead 2 connected? I keep getting Toolhead Disconnected errors and teh entire thing seems bricked. how do i get a replacement hotend with the proper cables?
If the head is ok apart from the nozzle, you should be able to reconnect it and use the other 3 as long as you’re careful not to select it when loading and slicing etc.
As well as contacting Snapmaker regarding a replacement, I’d order some nozzles and even complete spare heads.
