@xchrisd Really appreciate your time and effort. Will try again later.
Have an awesome vacation!!! Stay safe!
@xchrisd Didnât work. I am using PLA. The result is still the same even with your suggested setting.
I really donât understand why the Travel Path cannot be changed or at least give us an option or other detours.
You could do this with cura or simplify 3d
Had explored Cura and managed to resolve the issue. The printout was flawless! Played around with some gcode commands and the scripts but the scripts such as âChange Filamentâ or âPause at Heightâ scripts are not working as intended.
Thanks @xchrisd !
Do you mean when trying to print âChange Filamentâ or âPause at Heightâ , the same issue happens?
Can you show a picture of it?
Did you Cura to generate the gcode?
