So I’ve been printing PETG at 240 (bed75) on the snapmker 2.0 A350, and I chose new project, then changed the machine settings to the Snapmaker Original, then it loaded back to start screen and I chose 3dp again and it appeared to load a new project (but could have behind the scenes left the same start gcode for A350 PETG).
I changed to Raft bed adhesion, added the wheel-real model, chose Duplicate, chose Auto arrange (just fits). I changed the wall thickness and infill percentage, checked other settings but didn’t change, visually verified it was on PLA but didn’t change material. Then generated Gcode and exported to file. I sent this via octoprint because gcode generated has problems with temperature in comments due to mutliextruder (see other post).
Running the gcode on octoprint I happened to glance at the temperature graph which showed a significant change, and it was actually dropping from 240/75 (PETG temps) to 200/50 (PLA temps). I then checked the gcode, it shows the start gcode setting temps at 240/75, and then later the gcode changes to PLA after layer 0/1.
don’t know if their error message is still processed with, since there was a window of 1-2 weeks from 22.02.2022 to report and discuss errors!?
Here the original text (see marking)
