June 18, 2023, v4.13.0
Feature
2W Laser Module (2W Infrared Laser Module) compatible with (WiFi and Serial):
- Snapmaker 2.0 A250/A250T/F250 and Snapmaker 2.0 A350/A350T/F350
- Artisan
- Ray
2W Laser Module Default Laser Profile
A-B Position (support for 20W,40W,2W Laser Module)
- Operation Steps: After connecting the machine, open the AB Position panel. Use the panel to control the module’s positioning to the rectangular lasering area. After clicking the panel’s completion button, the canvas will highlight the lasering area, and you can print based on the position information on the canvas.
- Note: It is worth noting that AB Position is essentially a generated ordinary G-code, just its work-origin is the mechanical coordinate point (0, 0). After completing AB positioning and resetting the work-origin, you need to redefine the worki-origin as the mechanical coordinate point (0, 0), or click the AB positioning panel’s completion button again to set it automatically - this will set the working origin to the mechanical coordinate point (0, 0).
It is worth noting that AB Position is essentially a generated ordinary G-code, but its work origin is set to the machine coordinate point (0,0). If the work origin is redefined after completing AB position, the work origin of the AB position G-code (i.e., the machine coordinate point (0,0)) will be overwritten. You will need to redefine the work origin to the machine coordinate point (0,0), or you can click the “Done” button on the AB position panel again to automatically set the work origin to the machine coordinate point (0,0). Otherwise, the laser processing may fail.
Ray Add Control Mode.
Note:
- Maintain Motor Power-on Mode: When you enter this mode, the machine’s execution head will be in a powered-on state, and it cannot be pushed during this time.
- The G-code generated under control mode must be executed while the machine is in the power-on mode. Conversely, the G-code generated under manual mode must be used while the machine is not in the power-on mode
CNC 4mm tool Engrave Profile added.
Improvements
- Improvement: 200W CNC Module Default Engrave Profile.
- Improvement: Artisan machine settings, hide dual-extrusion for Snapmaker 2.0 select feature for better user experience.
- Improvement: Artisan 20W and 40W Laser Module input material Thickness print.
- Improvement: Artisan 20W and 40W Laser Module will turn off crosshair light after start cutting or engraving.
- Improvement: SM2 auto turn off laser after machine disconnected (The disconnection was initiated by Luban).
- Improvement: Added and improved Chinese and German language support for the software interface.
Bug Fixes
- Fix: Filled-Line gcode go to laser position with workpeed instead of jogspeed.
- Fix: Reconnected machine will clear pre-states: modules and cameracapture.
- Fix: Saving laser project file will contain auxiliaryAirPump, halfDiodeMode, constantPowerMode, initialHeightOffset.
- Fix: Can not select model after using Rotate on Face (3DP).
- Fix: Issue with rotating module running border on the B-axis with a value of 0 in specific contexts.
Download links
We provide Snapmaker Luban for different platforms:
macOS x64/ARM64
Windows x64
Linux
Please refer to our Github releases page to download.
Feedbacks
For the full user manual for Snapmaker Luban 4.0 and later, please checkout Snapmaker Luban 4.0 User Manual .
File a support ticket
Create an issue on Snapmaker/Luban
Email to support@snapmaker.com
