July. 29: v3.8.0
  • Feature: Add import and export for project files (#374)
  • Improvement: Improve user experience for project auto save (#390)
  • Improvement: Auto-adapt text size value based on its height when scratching (#377)
  • Improvement: Improve CNC G-code starter code to avoid collision (#382)
  • Fix: Fix DXF LWPOLYLINE first and last point not connected (#378)
  • Fix: Change the default behavior of “optimize path”, SVGs with more than 2000 shapes will not use the parameter (#388)
  • Fix: Fix wrong rotation of G-code thumbnail (#400)
Snapmaker Luban for macOS
Snapmaker Luban for Windows 32-bit
Snapmaker Luban for Linux 64-bit
Option 1 (recommended)
Option 2
Snapmaker Luban for Linux 32-bit
Option 2
Hint: To start Snapmaker Luban on Linux, you need to:
  • Add your user to group dialout: sudo usermod -aG dialout [your username]
  • Start executable: snapmaker-luban (.deb version) or ./snapmaker-luban (compressed version)
