Snapmaker Artisan Postprocessor (Fusion360 / SolidCAM)
Hi, I would like to use Fusion360 to create the G-code for milling with my Snapmaker Artisan. Unfortunately, I can only find a postprocessor for Snapmaker in general. Does the Artisan work with it? Has anyone had any experience with this?
Additional question: However, it would be best if I could use SolidCAM. However, I have not yet found a Snapmaker postprocessor for this. Is it very time-consuming to create this?
I’m just starting out, but have some basic knowledge of CNC milling, just not with Snapmaker or programming the post processor.
Thank you!
I read somewhere that you can use the snapmaker postprocessor for the Artisan.
Here you go:
https://wiki.snapmaker.com/en/general/manual/using_artisan_with_fusion360_for_multi_process_3axis_cnc
Yes, it works with the Artisan. I used it to mill a base plate for a marble clock and also to taper the leading edges of some plywood model rocket fins.
Thank you! Did you just import the post processor or did you edit/customize it in Fusion?
I installed the Snapmaker post processor.
