I am printing several things on the Artisan with a single filament, but the nozzle seems to rub against the infill when it moves. I did the Z calibration again and during the calibration I notice that the left nozzle does not lift while the right one does. is this normal? If yes any idea why is the nozzle rubing against the infill.
I also notice that the first layer is a bit larger than the rest. So probably the Z calibration is not good. I’ll try doing the Z calibration manually and see if that solves the problems.
As there are contradictory answers, I wrote to the support. I’ll post the answer on this topic. but now they are on holiday for the “Dragon Boat Festival”. Sounds like fun
I’m having a similar issue. It seems like the whole z-axis isn’t moving up far enough with each layer! I start with a good first layer, second and maybe third are fine, then it starts rubbing. I apply offset. A few good layers, repeat… until I reach the maximum of 0.5mm offset and it starts runining my print
