I have just tried out the CNC function of my Snapmaker for the first time, but it doesn’t work because the toolhead just hits the screws on the clamps. The clamps are set up identical to the instruction and I have also followed the work origin instructions thoroughly as well. Does anyone know how to fix this problem?
You may think you’re following the instructions, but you’re obviously doing something incorrectly. Do you have the correct machine selected in Luban? (I’m assuming you’re using luban)
Need a lot more info. What are you trying to do? Share screenshots. Gcode. etc.
