Snapmaker 2.0 problems, Pauses and starts again when printing
Anyone know what is going on here?
Starts off good and well into printing. Dose a couple layers lifts up and starts printing again. Most the time doesn’t even go back down to the tight height and Birds Nest!!! I’m rarely able to finish a print on any thing. Very frustrating! Can’t even attach the video…
Hi Aaronsware, you can contact our Support at support@snapmaker.com. :blush:
One week to get help?!
Is it possible that your filament is grinding in the print head?
Make sure your spool could spin as easy as possible, ideally the spool is straight above the center of the bed and the tool head and could be pulled easily.
Thank you for the response!
Yah, originally thought that was the problem.
Mounted above like you said. Feeds real nice.
Same problem though
