Preface
This report is primarily concerned with methods for optical calibration of laser engraving module. Light power is very important for the laser engraver, not clear standard has been established for the calibration procedure nor requirements of power meters suitable for optical power calibration. The purpose of the report is to provide guidance for establishing calibration procedures.
Category
- Beechwood
- MDF
More to be posted
Pattern definition
- Work speed: The speed at which the laser engraver is emitting
- Jog speed: The speed at which the laser engraver isn’t emitting
- Dwell time: Duration time of each point
- Laser power: 1.6-watt
Material list (More to be released)
Beechwood
Calibration pattern
We designed a matrix of squares, and each of them stands for different work speed and fixed power. The power and work speed is fixed and you can run the file directly.
Toolpath index
- Index: Work mode-work speed-Power ratio
Example: line-2500-5
Beechwood
laser-Line test.snaplzr
Laser-Dot test4.snaplzr
Recommended Settings
Movement mode: Line(Normal quality)
Result:
800mm/min+100% (Insufficient constraction)
500mm/min+50% (Recommended setting)
300mm/min+50% (Low work speed)
- Configurations form
Movement mode: Dot(High quality)
Result:
Recommended settings:
2500mm/min+60%(Recommended)
2500mm/min+50%(Insufficient constraction)
MDF
Calibration pattern
Form
Laser power 1.6-watt Jog speed 2500 mm/min
Movement Mode Line Work speed 800mm/min
Fixed power rate 70% Normal quality density 5 dot/mm
Luban Version V3.15 or later Hight quality density 7 dot/mm
Result:
800mm/min+70% (Recommended setting)
Laser power 1.6 watt Jog speed 2500 mm/min
Movement Mode Dot Work speed 2500mm/min
Fixed power rate 20% Normal quality density 5 dot/mm
2500mm/min+20%(Recommended settings)
2500mm/min+30%(Excessively Carbonized)
Basswood
Form
Result:
(Image here)
500mm/min+80% (Recommended setting)
300mm/min+50% (Recommended setting)
Luban Version V3.15.0 or later
Result:
2500mm/min+30%(Recommended settings)
2500mm/min+40%(Excessively Carbonized)
More to be released later
I hope you guys can post some test about dwell time.If the time also is a influence factor!!
