Laser Engraving Speed issues
Your posts pre-shipment showed good speeds (7-15 minutes for a print) - I’m printing a coaster now, work speed is 300, dwell time only 20, power set to 153 (60%) on a 3x3 bamboo coaster. resolution and depth look good and dark - but it’s been running 3.5 hours - with almost 4 hours to go (per the dashboard). For some reason, this doesn’t seem normal.
Do we have any sample setting guidelines for sample materials?
I guess you are using greyscale mode, which is slow comparing with B&W mode. Try B&W Mode, 800mm/minute for work Speed & 3000 mm/minute for Jog speed. And set laser power to 100%.
