Snapmaker 2.0 Brcing kit
Anyone having issues with straight line laser or cnc cutting since adding the bracing kit? I find that with the brace on the X axis I do not get straight line cuts, ther’ye all over the place. remove the brace on the x axis and it is back to cutting straight again. Looking into this further after removing one of the wheel / /bearings it looks like there is a concentricity error, probably with the plastic cover over the bearing. I am going to try to use a bearing without the plastic cover to see if thats better but might have to fit some brushes either side of the brace to sweep the x Axis front face clean or debris might make it worse.
I needed to tram my X axis, it was not parallel after assembling.
Did you report this issue to the support team? https://snapmaker.formcrafts.com/support-ticket
