Snapmaker 2.0 A350 tips for beginners
Here are just a few of the things which have made my prints much more consistent and better.
  1. Make sure you use an enclosure to keep your temp / humidity regulated.
  2. Use a filament dryer at all times, instead of just having your filament hanging out in the ‘open’.
  3. Make sure there is as little tension as possible on the filament coming into the print head.
  4. Do your E-Step calibration after changing your hot ends / print head.
  5. Make sure you used the beveled / recessed M4 bolts, to attach the heated bed.
  6. Use Cura for slicing, it does a MUCH better job than Luban; there is a Snapmaker plugin for Cura.
After I started following all of the above my results were much better, and far more consistent.
