Here are some test results that may help users set their 40W laser speed and power.
This first test done on 4mm Marine Ply (because it suited my project). I’ll do some other materials if this post is useful for other users.
The photo of the grid on the ply should be self explanatory.
The reverse side of the ply shows the impact of the excessive heat and flames.
I had the flame detector turned off so I could perform all the tests.
Each of the oval shapes that are missing either fell out or came out with a gentle tap and no dage to the plywood
The cleanest result was 70% Laser and 500 speed.
