Good morning,
On my workbench I use an old Sony Vaio Laptop as a machine interface.
As the Luban Linux version runs 5 times faster than under Win10 I’d prefer to use Luban under Linux.
Unfortunately the slicer preview shows a display error under Linux both with the program and in the browser. On the same unit the Windows version works correctly (but slow).
Luban is the actual version 4.8.2 completely removed and freshly installed.
I add the linux hardware system report.
All in all the new Luban version is nicely to use - I like it
Thanks in advance for any response!
Peter
Sony_Vaio.docx (6.3 KB)
I don’t think there areany people using Linux around here.
Did you submit a ticket? Support Ticket Form
Thank you, I’ll try this way …
For all LINUX users: Luban is supported by Ubuntu only …
new Luban user here, waiting for my Artisan to be delivered. I have changed all our devices at home to Linux as Desktop OS.
I can confirm that Luban has slicing problems on RedHat Enterprise Linux.
But it works on Debian and Fedora (upstream of RedHat) after installing the packages from Github.
Looks like the application requires some more recently updated libraries to get it working. I did not try it on Arch based distributions so far, but it would be similar as they are using typically RPM packages (after conversion).
