I received my Snapmaker Kickstarter reward yesterday and after the excitement of setting up and printing my first calibration cube, I’ve been a little disappointed with the results of some slightly larger prints.
I believe there is an issue with the Z-axis of my Snapmaker, whereby when the print head gets to a certain point, the Z-axis seems to shift (or drop, I’m not sure) but it causes part of the print to deform.
Here are some pictures to highlight what I mean. As can be seen, this artifact is repeatable - every time the z-axis gets to a certain height, this happens to the print:
You could try swapping it with one of the other actuators. Maybe one of the other ones would perform better. The unique thing about the Z axis is that it has to handle the load of the Y-axis actuator plus the print/cnc/laser module.
Thanks, that’s a good suggestion. I’ll give that a try tomorrow.
Just seems odd that it happens at exactly the same position every time. I’ve also noticed a sticking point on the X axis but thats far over to the left and may not be too much of a problem.
Are your cables restricting movement?
The aluminum extrusions could have a defect in the race way that is causing it to stick at that location. With the snapmaker turned off, you could try manually moving the axis in that region and see if it has resistance at that point or if the movement is fairly uniform.
No, the cables allow free movement for all axes - the cable arrangement isn’t nice but definitely not restrictive.
I tried “jogging” the Z axis and movement was smooth all the way along the screw. I’ll also try this manually on all 3 axes to see if there is any resistance.
If so please take a test cube model and elongate it in Z past the point where this is happening. Next slice it in vase mode. You just want the outer perimeter printed. See if the issue still happens. Report back with your results.
I have a feeling this isn’t an issue with Z but instead extrusion issues.
I’ll open up the end caps and check for tightness and Loctite them where necessary. If there was any looseness, I would expect to see markers during any stage of the printing process, not just at one certain height.
I will give the elongated cube a try also and, like you’ve said, I’m also now not so sure its a Z axis problem having thought about it a bit more.
