Hi there,
is there a way to remove the default profiles which i do not need?
Deleting them from the profile folder won’t help, they are getting copied over into that folder again.
Thanks
Hi there,
Thanks
Potential Solution: Delete files from the path below.
I have not had a chance to test it out completely, but at the very least it removes them from the materials profile window. I agree that it would still be nice if there was a native way to remove the materials. Not sure why there needs to be six different profiles for the different colours of PLA in the first place. Should just be one profile and the colour can be changed. Maybe need a second option if you have the dual extruder to display it right.
Anyway, this is the filepath where i was deleting things from:
C:\Users\user\AppData\Roaming\snapmaker-luban\Config\printing\a350_single
The files I deleted all started with “material.”; I did not touch the “extruder”, “machine”, or “quality” files.
Obviously, change the last folder to match your printer. I deleted the folders for the other printers with no issues.
