Hello
I change my windows version and my computer, so I want to export my material library from my old computer in order to import it in my new computer… Simple in theory…
And I would like to do that globally, not one item at a time… Is it possible ?
Where the material library is stored on the disk ? May be it’s possible to copy/paste a specific folder ?
I posted some info about how print quality profiles are stored on disk. I only print PLA, so I don’t have much to experiment with for material libraries. I imagine they will be near the profiles on disk, and copying the files should work the same way.
Hi
I have found a manual solution to copy / edit the Luban material library
Go under the folder C:\Users\YourName, you will find an hidden system folder “AppData”. Open it and then follow this path :
…\Roaming\snapmaker-luban\config\laser\a350_1600mw
You will find multiple json files, one by material definition
(and other subfolder, depending on your SM machine)
So it’s easy to create a zip file of the global config folder and copy it to your new machine.
The complete library will be transfered !
