Since short, I’m a proud owner of a second hand Snapmaker A350. It includes: 2 x single extruder, 1x double extruder, 1,5W laser, 10W laser,40w laser, 60w CNC, 200w cnc, air purifier, quick swap system, enclosure…I’ve made a good deal on this full package! And I’ve bought the infrared laser as well!
Now, I know a lot about 3d-printing (this is my 5th printer), so I think I know what I’m doing.
The first print failed…I extruded 50% of the first layer and then stopped extruding, printer kept working! Changed the extruder, same problem, changed the extruder to the double extruder…same problem.
Used Luban, Prusaslicer and Orca as slicer, nthing worked, kept doing the same…
Were you watching when it failed? The 2.0 had some issues with the filament location that caused binding. In those cases, the filament gear turned, but was unable to pull the filament through. IIRC, a lot of people relocated the filament spool to a better location.
