Prints are hard to remove from the bed
I find that my prints are stuck to the bed and not easily removable. Has anyone created or come up with ways to remove the prints with ease?
Is there such a thing as a magnetic or flexible print bed for the Snapmaker Original?
Unfortunately you need to build your own magnetic bed.- I did this long time ago but it was not that good like the original sticker.
You need to extend the offset of your calibration.- Calibrate less tight. :wink:
Alright, I will try and see if I can “re-calibrate” and be a bit more gentle. :slight_smile:
Less z is generally the solution.
Glue stick, blue tape.
Lots of discussion on this if you search.
A better palette knife may help you a lot.
For small to medium parts, I use a pipe wrench with flat jaws. :wink:
