I have generated the G code with Luban putting all the parameters related to speed with the same value. First test 20 mm/s and then 15 mm/s ( picture below ) .
Then after few first layers the machine is changing the speed. Once going 15 mm/s, then 20 mm/s and sometimes even 40mm/s, Is there any explanation for that ??
i have the same problem, everything set to 18mm/s (TPU)
generated the nc-code and i see F1080 (=> 18*60) and also F3600.
for my TPU prints it´s a problem, until snapmaker prints with 18mm/s everything is fine, but for infill he doesn´t use the settings from speed table and prints to fast.
Any one have idea how to also change the speed in Luban for the supports layer. I am also trying to print TPU too but having problem getting the supports printed as the speed is too fast.
