I’ve received the 200w CNC and bracing kit for my A350 and installed both today. Just wondering if anyone knows if the power boosted toolhead cable included with the 200w module is suitable to use with the regular toolheads (3d print, 10w laser, 50w CNC etc)? Or if it’s necessary to swap the toolhead cable back out to the optional when I swap back to these modules? Thanks
You can use all tool heads with the Y Cable.
Source here under 1. Connect the laser module with the controller. (green text area):
https://wiki.snapmaker.com/en/Snapmaker_2/manual/install_20w_40w_laser_on_350_models
The 200W CNC cable is the same as delivered with the 40W laser. If you have them, you have a spare.
Thanks Wyphorn, much appreciate. Didn’t see that in the 40w laser wiki as I don’t have that module.
See at the picture and in the box on this page.
Thanks @buckfast_beekeeper, saw it in the wiki and the 40w laser page now. @Snapmaker-Support might want to include it in the 200w CNC module wiki as not everyone will have the 40w laser.
