Please try again later
New here. Initial prints on the U1 are so amazing. But when I try to print now it keeps saying try again later. So I can’t use my new printer until “later?” How much later?
Howdo you connect the priner to your system (router)? Try LAN mode, in case you are using WIFI/Cloud mode WIFI/LAN should help.
I presume you are trying to print directly from SnOrca (having sliced, if the U1 is reachable on the network it offers “Print”).
Whilst convenient, this isn’t the only (nor necessarily the best) option. The drop-down where it says “Print” offers alternative actions such as Save G-Code. Saving the G-Code produces a print file you can print whenever you like, without re-involving the slicer.
The file can then be copied to the U1 using the Fluidd interface (Jobs panel, through SnOrca’s Device tab or in a browser using the U1’s IP address in the address bar), or copied to a USB stick and plugged into the U1 directly.
