Pla not sticking
Hello! My PLA is not sticking on only one part of the heated bed. I have calibrated and cleaned the surface with alcohol and cloth and have checked electrical connections, all to no avail.
@MapMaryAnne what firmware are you on?
Try cleaning with dish soap and water. While IPA removes most stuff some stuff comes off better with soap. (Personally I mostly use IPA, but occasionally I’ll use soap followed by IPA just to be extra sure and remove any possible soap residue).
Iv’e been using hand sanitizer as I didn’t have any IPA on hand but recently started using window cleaner and it’s better then hand sanitizer lol
Hello! I am on the latest one, I believe
Thanks very much! I have used some rubbing alcohol and a soft cloth. I also didn’t realize that you could customize even more of the print settings in Luban, so I gave that a try and it seemed to have resolved the issue.
Thank you for your help, though!
I’ll have to give that a try! Thanks! :slight_smile:
