Paxx12 Firmware — Two Integration Questions: Spoolman Multi-Extruder Tracking + T0-T31 Fluidd Tool Panel
Hey everyone — I’ve been building out a pretty comprehensive setup around my U1 with Paxx12 and running into two issues I’d love community input on. Posting here alongside Discord and Reddit to cast a wide net.
My Full Setup:
- Snapmaker U1 — all 4 toolheads active, 0.4mm hardened steel nozzles on all toolheads
- Paxx12 1.4.1 (paxx12-19) as firmware — Fluidd as web UI
- Spoolman running in Docker on a dedicated local NUC (172.16.1.203:7913)
- Moonraker connected to Spoolman via [spoolman] block in moonraker.conf
- SimplyPrint connected for remote monitoring, webcam feeds, and print queue management
- Tailscale VPN for secure remote access across all devices
- 65 spools in active inventory — all entered and tracked in Spoolman
- Creality Space Pi X4 filament dryer above the printer feeding via PTFE tubes
Issue 1 — T0-T31 Showing in Fluidd Tool Panel
The Tool section in Fluidd displays all 32 tools (T0-T31) instead of just my 4 physical toolheads. I researched this and found GitHub issue #344 which explains the extra tools are internal Paxx12 macros used for full spectrum color mixing and other firmware functions — so I understand the reason they exist.
My questions on this:
- Is there a safe way to hide T4-T31 from the Fluidd UI without deleting the underlying macros or breaking any Paxx12 functionality?
- Is editing fluidd.cfg to suppress the display of unused tools something that’s been done safely by other users?
- Or is this simply something we live with on Paxx12 for now?
Issue 2 — Spoolman Only Tracking Primary Extruder, Not All 4
This is the more important issue. Spoolman IS connected and working — filament usage tracks correctly in real time for the primary active spool. However after completing a 2-color PETG print tonight using two extruders simultaneously, only the spool assigned to the primary extruder showed gram deductions. The second extruder’s spool remained at 0g used despite definitely printing.
Current confirmed state:
- [spoolman] block active and confirmed in moonraker.conf (server: http://172.16.1.203:7913)
- 3 spools assigned to printer slots #1, #2, #4 in Spoolman with correct locations
- Primary extruder tracking:
working perfectly, real-time gram deduction confirmed - Secondary extruder tracking:
0g recorded after multi-color print - Fluidd Extruder dropdown in Tool panel does not appear to affect Spoolman assignment
- Is multi-extruder Spoolman tracking actually implemented in Paxx12 / Moonraker for the U1?
- Is there a specific Moonraker configuration needed to enable per-extruder spool tracking across all 4 toolheads?
- Has anyone successfully got all 4 extruders reporting usage to Spoolman independently?
- Or is this a current Moonraker limitation for multi-toolhead setups that isn’t yet implemented?
I’m happy to share my moonraker.conf [spoolman] block or any other config details if it helps diagnose. Thanks in advance — this community has been invaluable getting this setup dialed in.
