Snapmaker U1 Spool Tracker v1.0.1 — Preflight Filament Checks & Automatic Spool Tracking
Hi everyone,
I’ve just released Snapmaker U1 Spool Tracker v1.0.1, a small local utility built specifically around the U1’s four independent toolheads.
The idea is simple: assign a physical spool to T0, T1, T2 and T3, store the remaining filament weight, and let the app check whether every spool has enough material before printing.
When Snapmaker Orca exports G-code, the tracker reads the per-tool filament requirement and performs a preflight check. If one of the assigned spools does not have enough filament, you get a warning before export and can either cancel or continue anyway.
The optional U1 monitor uses the printer’s local Moonraker API for automatic accounting:
  • Exporting or uploading a file does not deduct filament
  • A matching print becomes active when it actually starts
  • Filament is deducted only after the matching print completes successfully
  • Cancelled or errored prints do not deduct the full planned amount
  • Completed jobs are protected against double deduction
The current version also includes:
Download / source:
I’ve manually tested the packaged macOS app, real Snapmaker Orca post-processing, and the complete print lifecycle with a local U1/Moonraker simulator.
The Windows build passes CI, but I haven’t manually tested the Windows GUI yet. I also haven’t validated this release against a physical U1 in this test cycle.
So feedback from actual U1 owners would be especially valuable.
Update: v1.1 beta is available
The tracker can now detect and check a print started from the U1 screen or sent from Orca. The check happens after the printer starts; the optional pause-on-risk mode is experimental.
The beta also adds estimated filament accounting for supported completed prints and, when enough data is available, partially completed cancelled prints. If the tracker can’t determine the allocation reliably, it leaves the job unaccounted rather than guessing.
I’ve tested some of these workflows on my U1, including a manual pause/resume and a cancelled print. Automatic switching to another spool after runout has not yet been tested on a real printer.
Builds are available for Apple Silicon Macs and Windows. The Windows build passed automated tests, but its interface and connection to a real U1 haven’t been manually tested yet.
If you’re moving from v1.0.1, export a backup first, then import it into the beta and check your spool assignments and balances. The release page links to the installation guides.
Download the beta and read the release notes: Release Snapmaker U1 Spool Tracker 1.1.0-beta.1 · gromvs75/snapmaker-u1-spool-tracker · GitHub
If you try it, I’d appreciate feedback on your print-start workflow and whether the filament accounting matches what you expect.
Warning, the post by primeonyx933 is spam/phishing. Please do not click the link!
U1 Spool Tracker 1.2 beta released — automatic Snorca filament forecasts
U1 Spool Tracker 1.2 beta is now available on GitHub as a pre-release, with downloads for macOS Apple Silicon (arm64) and Windows x64. The new workflow checks whether your recorded spool balances are sufficient after slicing in Snapmaker Orca (Snorca), before you decide to print.
Windows GUI, real Snorca slicing on Windows and automatic window display on Windows have not yet been tested. The Windows executable is available on the release page and passed CI tests and its packaged self-test; it still needs a separate desktop test.
With Tracker running in the menu bar/tray, complete a slice in Snorca. Tracker detects the result and automatically shows Overview with the estimated usage and green ✓ / red ✕ indicators beside the heads. For multiple completed plates, select the plate to check; the forecast is for that plate, not the combined total. There is no manual G-code export, file selection, or modified slicer involved in this forecast workflow.
For example, if a plate needs 80 g, the assigned spool has 77.5 g, and the configured reserve is 5 g, Tracker shows a shortage of 7.5 g including reserve. This is an estimate based on the slicer and the recorded balance. Slicing does not deduct or reserve filament. Reslicing updates the forecast, and Tracker’s forecast feature does not upload or start a print.
Current validation status
  • Real slicing in Snorca GUI, reslicing and multiple plates were tested in an isolated macOS Lab.
  • The integrated main application’s Mac window was checked with offline test files, including plate selection, repeated auto-show and shortage indicators.
  • The published macOS arm64 and Windows x64 packages were built from the same commit and passed CI tests and packaged self-tests. The Mac package also passed signature verification.
  • The Windows offline test kit is prepared but has not been run here; successful CI is not a substitute for the GUI check described above.
Before trying the beta
Packages target macOS Apple Silicon (arm64) and Windows x64. The Mac app is ad-hoc signed, not notarized; the Windows window requires WebView2.
The beta uses an empty, separate inventory and does not automatically import or synchronize your existing Tracker data. Backup import is available, but a normal backup may contain enabled printer-monitor settings. Use the dedicated isolated test mode with artificial inventory for offline testing. Keep the beta separate from your installed Tracker.
Material mapping for the slice forecast is currently assumed: 1→T0 … 4→T3, and is labelled accordingly. The forecast follows the most recently completed slice project; simply opening or editing a different project does not replace it. File-layout support is based on Snorca 2.4.1, and a green check is not a guarantee that a print will complete.
Share your impressions
I’d love to hear your impressions of the new version: is the forecast clear, is the automatic window display useful, and is anything missing? If you run into a problem, please describe what happened and include your OS and Snorca versions.
Feedback from Windows users would be especially helpful. I don’t have a Windows computer, so the interface and automatic forecast display after slicing have not yet been checked on that platform.
This is a public beta, not the stable release.
Download 1.2 beta — macOS / Windows · English guide · Source code
Spool Tracker 1.2.1 — for the original U1 firmware, with a quieter Mac workflow
First, an important clarification: Tracker is designed to work with the original (stock) Snapmaker U1 firmware. No custom firmware, flashing, or additional components on the printer are required. The application runs on your computer.
I’ve released 1.2.1 with a more convenient way to see the result after slicing in Snorca.
On macOS:
  • The main Tracker window no longer pops up after slicing.
  • The menu opens automatically from the menu bar, with no Dock icon.
  • Green checks and red crosses show whether the assigned spools have enough filament, including the reserve. Each used head shows the estimated amount left after printing or the shortage; unused heads remain neutral.
  • The menu identifies the latest completed plate and its timestamp. Changing a balance updates the result without reopening the menu.
  • Clicking the forecast opens the full Overview when needed.
The new menu text is translated into English, Russian, German, Ukrainian and Spanish. Windows updates its tray icon and menu, but automatic menu opening is currently macOS-only.
Downloads: Release 1.2.1 — Stock U1 firmware, forecasts in the menu bar · gromvs75/snapmaker-u1-spool-tracker · GitHub
The release includes macOS Apple Silicon arm64 and Windows x64 packages, SHA256 checksums and build information. Windows GUI and real Snorca slicing on Windows are still unverified. Passing automated tests and the executable self-test does not replace that desktop check.
The update keeps the existing 1.2 beta inventory; back up before replacing the app. Menu Test inventories aren’t imported automatically. No modified printer firmware is required, and this update doesn’t add RFID or Spoolman integration.
The usual forecast limits remain: consumption is a slicer estimate, material 1→T0 … 4→T3 is an assumed mapping, and the result applies to one completed plate. Slicing/reslicing doesn’t reserve or deduct filament and doesn’t start a print.
Thanks for the feedback so far. Feel free to share your impressions of the new menu behavior.
U1 Spool Tracker 1.3.0 — Spoolman integration without changing the printer firmware
Version 1.3.0 adds optional Spoolman integration to Snapmaker U1 Spool Tracker.
Spool tracking and usage forecasts for Snapmaker U1 — without firmware changes.
Connects through Tracker. No components need to be installed on the printer.
The printer continues to run its original U1 firmware. Snorca provides the sliced print data; Tracker associates a registered print plan with the printer’s observed print and submits consumption after a matching successful completion. Spoolman stores the external spool catalog and balances.
You can begin with catalog reading only, assign Spoolman spools to T0–T3 and inspect the forecast after slicing. Slicing never deducts filament. Usage delivery is a separate opt-in setting and requires confirming that this Tracker is the sole sender for that U1.
The integration keeps a persistent delivery queue and protects against repeated print events. A lost write response is marked uncertain and requires review; it is not blindly retried. Restoring a Tracker backup disables the Spoolman integration and marks unfinished deliveries uncertain. The backup does not roll back balances in Spoolman.
The release also retains the macOS menu-bar fixes: slicing opens the result menu without opening the dashboard, and the requested dashboard can be brought forward without losing the system menu bar.
Supported server: Spoolman 0.27.1, installed separately. Forecasts remain estimates, and the pre-print material-to-head mapping is visibly marked as assumed. Successful accounting requires a registered, matched plan and verified mapping. Start with read-only mode and read the guide before enabling sending.
Validation used artificial spools, a local Spoolman server and a U1 simulator, covering multi-color consumption, all 24 head permutations, connection loss, duplicate events and backup restoration. Real U1 printing with Spoolman and sustained operation still require user validation. Windows GUI and real Snorca slicing on Windows remain unverified. Automated Windows tests and the packaged self-test passed. macOS targets Apple Silicon and is ad-hoc signed, not notarized.
Export a JSON backup before upgrading. Version 1.3.0 keeps the 1.2.1 inventory directory; Preview data is not imported automatically. Avoid running two senders for the same printer.
Spoolman is an independent MIT-licensed project by Daniel Hultgren. Its server is not bundled with Tracker; the release includes attribution and the upstream license text.
Hi everyone! :waving_hand: Here’s a quick Mac demo of U1 Spool Tracker: slice in Snorca, then check the filament forecast in the menu bar and dashboard.
It works with stock U1 firmware. Slicing only produces an estimate—it doesn’t deduct filament.
I’m looking for a few testers, especially Windows users and U1 owners interested in the optional Spoolman integration.
Windows GUI and real Snorca slicing on Windows remain unverified. Real U1 printing with Spoolman and long-running use still need validation. This video demonstrates the Mac forecast workflow.
Interested? Visit the welcome Discussion for setup links and to share your results. Please include your OS, app versions, and what worked or didn’t.
Thanks for helping improve Tracker!
Hi everyone! I’m looking for 2–3 U1 owners to help test Spool Tracker, especially on Windows.
A quick check would already help: does the app install, launch, and connect to your U1? Please share your Windows version, Tracker version, and any errors. I’m happy to help with setup here in the thread.
Windows GUI and real Snorca slicing on Windows remain unverified. If you use Spoolman, I’d also appreciate help validating the integration during real U1 prints — that still needs testing.
Thanks!
