Hi Snapmakers,
I did my first print, and I miss on-the-fly control for material flow rate and parts cooling fan. Is there any? If not: I’d like to suggest this as a future feature! It’s sometimes necessary to have this.
Thanks for suggestions!
Hauke
Hi Snapmakers,
Hauke
If there is a way I haven’t found it yet. And I agree this should be added to the next firmware update @staff
Hi all, I will forward your suggestions to our team
@JKC20: Thanks a lot!
As a follow up: Having a part cooling fan control and a feeder manual control (manual extrude, manual retract) would be great also!
I completely agreee, we miss manual control of flow and and fan!!
This should be a simple “feature”. the g-codes m106 m107 are working, however, in order to change the values, i need to plug in a usb cable and use the console to transfer the code. as the printer is not located in my office room (it would be rather noisy, would not it
) it is really cumbersome … i have to place an additional computer next to the A350. does not make sense, as there is already a neat android device attached …
Idea: why not add a gcode console like luban has to the android app too?
