New u1 with first layer and final layer problem. (Help)
I have a brand new u1 and did all the calibrations for set up etc etc and when doing my first print (snapmaker dragon) the first few layers were terrible. The sides of the model look great.
I also did a hueforge print with terrible top layers.
I think the nozzle is too far from the bed as I can see gaps between the layer lines put down on the bed and the top surface of print, I can stick my nail between the lines on the top agave in areas.
However I messaged snapmaker and they said they thought it was too close to the bed and I should lower the nozzle.
What do you all think before I go making changes? The red print is picks of layers 1,2,3 and the green pic is labelled as to the layer it is on.
I also just started another print in orange and am including the pics of its first layer also.
And now there is also a pic of a blue and green piece to show what all my top surfaces are coming out like. It’s basically a cross hatched pattern and not smooth at all.
(These are all prints from snapmaker app with settings unchanged).
Thanks everyone!!!
Why? What do they have to do with a Snapmaker U1?
Did you do the full installation process – ie calibrate toolhead offsets, run a bed mesh calibration, leave Heated Bed Calibration enabled on the print screen?
TBH, those pictures of the first layer of the baby dragon test file don’t look like a disaster…
I think its an auto-correct from HueForge
The orange filament is under extracted & the red is over extracted, are they the same brand and have you been messing with any settings so far?
Oops. I typed flash forge but meant snapmaker lol.
I ran all the calibrations and followed the instructions exactly. I also ran another bed calibration after the red dragon. Now every print (the green and orange prints) seem to be too far from the bed and leaving gaps between the lines.
And for the first layer not looking bad as you mention; it is a very far cry from my Bambu a1 printer. I mean it’s night and day better on my a1. Plus it’s leaving a bad top surface also.
Haven’t changed any setting at all, the red is the pla that came with it and all others are brand new elegoo petg. The orange is not a hueforge print, so it can’t be the settings in hueforge.
PLA & PETG don’t like each other, so if you aren’t already you should be washing the build plate(s) as that can cause errors, I have different plates for different materials cos I can’t be arsed to keep cleaning them
Have you calibrated the filaments? I find default profiles are as much use as a wet fart in clean pants…
I clean the plate very well between prints. And I’ve only done small stuff so far and no matter where it is on the plate, I’m getting gaps between the lines on the first layer.
The sides of the models actually look really incredible to be honest!!
It’s just the first layer(s), the first 2 are the worst looking, and the top layer that aren’t coming out proper.
Actually the print I have going is now this far and the sides are plenty good for me for a stock setting for now. I’m really happy with the performance in general also.
Im going to try adjusting the z offset and see what happens. I got the ok from snapmaker that it won’t ruin my warranty if I change it.
OK that’s fine you do you, I’m not going to waste anymore time here
I am still waiting for my snapmaker u1 but but based on other machines I have used I would try adjusting the z offset. Only in small increments as it should be very close to correct already.
