Hi all.
Just instead all the new linear modules. 8mm on the Z and the 20’s on x and y. Cables all connected, firmware updated as some as I powered. But once it rises to home, no movement whatsoever. Any suggestions?
Hi all.
With the power off, first make sure that the cables are going to the correct Splitters, and the correct Controller ports. Then try reseating each of the connectors. And to be clear, you are on firmware 1.14.2, correct? You didn’t state that in your post.
I am. Thanks for the help. Reseated all the cables, powered off and all is working!
