Hi!
I’ve tryed to print it with the face down and support but still not great result:
after removing the support the head is not so fine… the thread seems ok but in one face it’s flat and unsuccessful.
I’ve printed using reccomended high quality on Snapamkerjs SW
What is the highest resolution we can get with the Orginal? I was supposed that 0.1mm used on High Quality reccomended settings it’s the highest! We cna go to 0.05mm? Do you have a custom settings to share?
It’ll allow 0.05mm. I just copied the High Quality, and changed the Layer Height and Initial Layer Height to 0.05mm. I use this to test my calibration by printing a 0.05mm thick sheet.
I still don’t see a way to export Profiles in SnapmakerJS. They’ll probably skip it, and will implement in Luban.
