Hi everyone,
We’d like to share a high quality CNC project from community member Dominik Bilitewski, now published on the Snapmaker blog. ![]()
In this article, Dominik walks through the full process of milling wooden chess pieces using the Snapmaker Artisan with the Rotary Module and Fusion 360. From rotary axis alignment and zeroing strategies to roughing and fine finishing toolpaths, the guide is detailed, practical, and based on extensive hands on experimentation. Even if you are new to CNC or rotary machining, there are many takeaways that can help you avoid common pitfalls.
If you are interested in CNC carving, rotary machining, or simply appreciate well documented projects, this one is well worth a read.
Read the full article here:
And a big thank you to Dominik for taking the time to document and share this work with the community. ![]()
