The sm2 seems to be ignoring the M104/M109 temp setting codes, when sent through octoprint.
I would attach the gcode but being a new user i cannot
Expected the nozzle temp to change each level
Actual, it hits the initial 205 and wont move from that setting.
I found this was a bug that was meant to be fixed in latest firmware…its not fixed
Also running though octoprint and removing the touchscreen made no differance.
Because of this If your using prusaslicer, the first layer temp is used for the whole model, regardless of the other layers setting for the nozzle
Please @staff can this be sorted asap
