What is the maximum height of an object you could laser on. I don’t mean cutting, just vector or gray scale. I have a block of 87 mm and it is failing on distance calculation and when I try to engrave by setting height manually it is totally off the laser starts beside the object. When I try it on 36 mm, I have no issues at all. Can’t it handle 87 mm height? Is there a chance someone could try this as well and let me know if you see the same behavior? PLEASE
Here is what I tried Snapmaker Original/2.0 Owners | Facebook Thank you to anyone assisting.
Snapmaker A350 with 10 watt laser
