Maximum Laserable and Routing Height?
For the SM A350:
What is the maximum height of an object that I can laser engrave/etch? I already have an understanding of the laser cutting limitations. For example, can I put in a 5in block of wood to engrave an image onto?
Same for CNC…can I put in a 5in block of wood and carve an image? I already have an understanding of the depth limitations from the bits being used.
I Just can’t seem to find the answer on the Forum or the SM website.
Thank you.
Yes.
Also yes.
Usable height looks to be around 11" including a bit of tool stickout and whatnot
Thank you for the clarification!
Of course!
I should mention the “auto” way of setting tool height is not conducive to tall objects. But there also is a “manual” way that involves manually touching off, much like a manual mill. Pretty much the entire build volume is usable. However very heavy objects will push the limits of the Y axis and don’t expect quick acceleration - your toolpaths will have to take the machine rigidity into account when you create them if you have a 10"x12"x12" solid block of wood on the table.
Thank you again. You’ve been exceptionally helpful.
Brent my 10w laser does not go above 35 mm any idea why it wouldn’t ?
