Material Thickness
Hi
I am using Luban as my software and I am cutting simple shapes in 0.030 Polypropylene.
The issue I have is that the thinnest option I see is 1.5mm in Luban and I am 0.75mm. Secondly, this is a repeat job so we are just cutting the same file ove and over.
Sadly after each cut we need to reload the file then refocus for the thickness of the material. Is there no way to just change the material and repeat?
Thanks
Corry
