Hi, I am trying to calibrate my extruder and following the advice from mattshub (linked in another post on the forum). When I enter the M503 command to check the “E” value the terminal responds as follows:
M503
ok
I do not receive other data to work with. My extrusion head consumed 94mm of PLA when I commanded it to extrude 100mm, so it seems clear that I should tweak the steps per mm setting.
Hey @mechan8
it seems your printer is not connected to the terminal.- be sure to be connected to the correct port.
Maybe get the printer to home pos, or move axis with snapmakerjs, luban or any other slicer.
Hi @xchrisd, thank you for your quick response. I should have included more detail in my question. Prior to sending the M503 commend I sent these other commands successfully:
M83
G1 F50
G1 E100
I think Luban must be communicating okay, right? I am connected via wifi in case that makes a difference.
