Thank you for the Solution??? It did work, but 1 day later it is the same.
Obviously there must be a correct way of fixing this or avoiding it happening again.
What do we need to look for to assist.
@Burgerboy the solution that I ultimately deployed and was successful, as in I could finally paint, slice and send the gcode electronically to the machine and print objects, were the instructions that @Riskey provided: Luban V4.5: Known Issues & Corresponding Solutions - #15 by Riskey
Since deleting all files on my computer, including directories, reinstalling software and firmware, including resetting the machine to factory defaults, I have not (knock on wood) had any subsequent issues – see prints: Air Spinner by walter; Crown of Malric; Under Mount Paper Plate Dispenser;
Same issue and it’s annoying. Especially cause I am new to it and didn’t even know initially I wasn’t seeing something that I should.
Did you find a solution? I even tried going to Fullscreen thinking for sure it will fix it to no avail.
Thanks
