I believe I’ve encountered a Luban CNC tool path generation bug. Luban software and device firmware are the latest versions available (details below). The STL file previews correctly:
Don’t know about the problem with the tool-path, but you don’t need that small of a stepover for a flat end mill. 1/3 the diameter at smallest, and just less than the diameter at most.
Thanks for the tip. Since the tool path generated by Luban was back-and-forth and I want the inner edge of the annulus to be smooth, I assumed that I’d need a small stepover to avoid getting a bumpy edge. But most of my CNC experience so far has been with the carving v-Bit.
I’m new to Snapmaker and this forum, but I’m surprised that nobody from Snapmaker support has said anything at all here after three weeks. Does Snapmaker support monitor this forum at all? If so, it would be nice to get some sort of response like “Thanks for the bug report, can you send use the files so that we can try to debug it?”
SM staff is pretty non-existent on here other than when they post software updates or announcements.
Bugs should be reported at Snapmaker · GitHub under the relevant section.
