Luban and Fusion 360 - Printing two materials
I want to print parts with two different materials on the Snapmaker J1.
The parts have many different “bodys” in F360. I see no possibility to export the complet “combination”. I can only export singel stl- files. So i get a puzzle in the slicer. Has anybody a solution fpor this problem for Cura or Luban?
Did you check if Fusion 360 can export 3MF files? It seems it can: How to export Fusion 360 designs in a 3mf format using a custom workplane reference
3MF files should keep object arrangement, and you can assign extruders to every part of an 3MF file.
