Luban 4.15.0 * Current Progress shows nothing
HI all,
Does Luban care about the source of the G-code to display the current processing status?
When I start a print job and load a G-code file from Snapamaker Orca, I can see that the printer is running, but not the status (it’s always zero). I can see which G-code line it’s currently on, but not how many lines it’s on! Is that normal?
If I import a file from Cura, for example, the status display works perfectly!
Has anyone else experienced this problem or have any ideas on how to fix it?
I think it’s a known bug but for clarification, where do you start the print?
I save the G-code from Orca to the hard drive and import it into Luban to start the print. Then, the elapsed time and current G-code line are displayed in the status, but not the total number of lines to be processed, etc.
Thank you for clarifying.
There is a new beta firmware where you could send and start the gcode from Snapmaker orca directly, if you are interested, have a look here (attention you need to set the quick swap and bracing kit status in the settings menu before leveling!
I think Luban is not actively developed anymore but let the know by opening a ticket
https://support.snapmaker.com/hc/en-us/requests/new
Hello!
I haven’t tested the mentioned firmware yet, but I’ve also tried printing directly from S-Orca. The transmission works, but even in this case, no status display is visible. Only the G-code lines that have already been processed are shown.
Also, the estimated remaining time calculation on the controller differs significantly from the slicer result.
