Lightburn library for 10w laser
I’ve started porting the 10w laser configs over to lightburn as a lightburn library file, but figured I should check in case anyone has already done it (or has better settings than the defaults).
Here’s what I’ve got so far (note: TOTALLY UNTESTED, I was literally just copying json files to XML files, guessing what the translation between the 2 totally different formats/definitions are, use at your own risk!):
luban.zip (1.6 KB)
If anyone’s got a library they’re building though (I do plan to finish porting over all the Luban defaults soon, but many of them will be relatively untested for a good amount of time), I’d love it if you could share your settings. I’d be happy to combine them into a single file and make a shared library (if there’s enough interest, I can start up a github repo and accept/curate imports).
