Lightburn Camera choices and Mounting
Hello everyone, hoping some has some experience and advice. I’m looking at buying a lightburn camera and mount. I have the Snapmaker 2.0, with the A350 enclosure and I am planning to mount the camera on the ceiling of the enclosure, centered above the bed. Ideally, I’d like to get the 8MP LightBurn Camera (4K-W) 85 degree. However, I’m worried about clearance and if there is enough height to the enclosure. I’m seeing conflicting information online. They also don’t allow returns on cameras so I want to make sure it will work. Any assistance is appreciated.
I have mounted a camera in the front left corner of the enclosure.
If I would plan to mount a camera top center I would drill a hole slightly larger than the lens and mount the camera on top of the enclosure instead. Specially with the air-aissist clearance is really tight above the head.
But the reason I mounted the camera in front instead of on top is that I want to see the actual cutting/milling occur and be able to react to issues related to that.
